Register now for our webinars about the new functionalities in "LTS 2026"
February 18: Webinar Tygron Platform 2025; High Performance GIS, Artificial Intelligence and Digital Twins.
We understand that an engineer needs control over the input data and the calculations in order to guarantee the results of this calculation. After all; a calculation result is as good as the input data. That is why we are developing the Tygron Platform as an open calculator, which gives you the opportunity to integrate data yourself, enrich your own data with Artificial Intelligence and build your own simulations.
On February 18, 2025, 10:00 – 11:00, we organizied a webinar for engineers and data experts who already work with the Tygron Platform. The following topics were discussed:
  • Geospatial Artificial Intelligence (GeoAI)
  • High Performance GIS
  • Digital Twins
Watch the full webinar here:
View the sheets here: Download PDF
View Ward’s presentation here: Download PDF
The functionality we showed during the webinar is available on our Preview Server.
  • If you are interested in getting started on the Preview Server yourself, request access by sending a message via the contact page on this site or by sending an email to support@tygron.com
  • Also check out the more extensive information about the Nieuwegein project, available documentation such as AI Suite, and our training offer Tygron Academy
  • Do you have any questions? We are happy to help you via support@tygron.com.
Geospatial Artificial Intelligence (GeoAI):
Geospatial Artificial Intelligence (GeoAI) combines the strengths of AI and GIS. In this webinar, we showed how you can use this for your own projects.
To apply AI as an expert, you need data, computing power and a neural network. You are of course familiar with the Tygron Platform for processing large amounts of data with an awful lot of computing power.
In this webinar, we showed how you, as a user of the Tygron Platform, can train your own neural networks or use a trained model, using a number of concrete examples:
  • How you can get started with Artificial Intelligence to generate better input data for your calculation models.
  • How you can use it to perform better analyses in the field of heat stress, climate, biodiversity and health.
  • How a neural network works and how you can use it yourself as an expert or further develop it for your own specific use case.
The Tygron Platform is developing as an open calculator, which gives you the opportunity to integrate data yourself, enrich data with Artificial Intelligence and build your own simulations. We discussed the following topics using a number of concrete examples:
  • SimNL: calculating the whole of the Netherlands. We showed all the technological developments behind this and what this means for you as a user.
  • One of the biggest developments we have worked on in recent years is the possibility to create your own calculation models and large-scale GIS analyses. Functionalities that many users already work with are the combo overlays and TQL. A new component in these developments is the possibility to calculate iteratively between different simulations and with different input parameters.
Digital Twins
Several municipalities, provinces and water boards are developing Digital Twins. The Tygron Platform offers a computing core for your Digital Twin. In this webinar we will show a number of examples.
How you can get started with the latest developments yourself?
There is a new release cycle, in which we no longer implement all new developments for everyone on the LTS at a fixed time in the spring. Now that the Tygron Platform is being used more and more widely, many users want the LTS to be an environment that does not change every year for longer.
So how do you get access to all these new developments? We would like to tell you about the new release cycle and how you can get started with all these great developments.
